Installing a large 220cm x 140cm window
31 May 2005
London
I have a 3m x 3m conservatory which will be knocked down and rebuilt from scratch with a new large UPVC or Aluminium window W=220cm H=140cm. I plan to buy a polycarbonate 25mm roof for the structure.
My question is: Is 20cm of brickwork on top of the window enough to hold such a large window, or should I re-think my window size?
Is it easier for builders to install aluminium or UPVC window (which one will cost me less)? Any advice would be greatly appreciated.
Window wall plan: http://www.zen7142.zen.co.uk/mywindow.gif
who cares what it costs (ali v pvc) the questions you should be asking is will it match what i have, will I (that is you) like what it looks like.
remember you will have to look at which ever you opt for for some years to come
Hm - I seem to remember that building regs require an 800mm return between corners and windows - you only have 500mm on your diagram. Could be wrong of course.
the window will be secured in at the jambs, not the head of the window. how are you going to support the brickwork over the window though?
Thank you all very much for your comments.
I have no idea. I just worked out the plan from what I have at the moment (poorly executed DIY job from the previous owner). Current structure has two evenly spaced single glazed windows (which are in very poor condition) and 20cm of brickwork on top. I think this structure is part building blocks, part bricks. I thought I could do the same but put in one big double glazed window.
Am I planning this all wrong?
Use something like catnic lintel for the brickwork on top etc
I've always known it to be 450mm on return corners, check with BCO.
UPVC window will be cheaper than aluminium window, even more cheaper if you have a local window company selling reject window.
