is there a better way to hold up the brickwork above it than using props that go through the wall above the lintel?
View media item 21092 [/img]whats a strong boy
You could use a strong boy? does away with props both sides of the wall
You will have the lintel in place.
Sorry i mislead.
By, 'you will have the lintel in place' meant position the lintel at the bottom of the wall ready to be lifted in. then, when you fit the acros you won't need to thread the lintel around these obstacles.
Will they also support the inner leaf?
Possibly.
Do the floor joists land on the proposed wall?
If they do, then all you need to do is acro the joists via a sturdy batten against the ceiling.
