Can a single socket be installed from a 13amp Switched Connection Unit or would it need to goto a existing double socket in my kitchen?
I would like to have installed an extra socket in my living room. I have a open planned Living Room and Kitchen.
In my kitchen I have a 13amp Switched Connection Unit which I believe is connected to my hot water tank, this Connection unit has 2 wires running in this.
Can a single socket be installed from a 13amp Switched Connection Unit which is connect to the hot water tank?
I want to do most of the work myself, chasing the wall to lay the wire, drilling threw the wall, re-skimming the walls THEN I will call out an electrician to connect it...... but it if not possible, at least it will save me time in chasing out my wall!
Thank you.
Thank you.
