- Joined
- 16 Feb 2009
- Messages
- 2
- Reaction score
- 0
- Country
I want to install an electric fan heater or element heater about 2.2 m up on a bathroom wall. The heater will be placed on an opposing wall to where the bath and sink are situated. It would be 1.7 m horizontally from the nearest corner edge of the bath and 1.6m higher than the top of bath. It would also be 1.4 m horiz away from the nearest sink edge but 1.5 m higher.
I wish to drill a hole in the wall to where the side of the heater wll be, through the red brick and plaster wall into the landing cupboard next to the bathroom, where there is an unused FCU for a removed immersion heater. I believe Iwill need another FCU next to the heater.
The existing FCU is supplied by a dedicated 2.5mm sq twin core and earth cable from the consumer unit. This cable is 14m long.
The bathroomh is limestone floor tiled.
My questions:
1. Would my heater positioning satisfy the relevant zoning regulations and if not how could it?
2. Does the cable fed through the drilled hole in wall have to have any conduiting?
3. The existing FCU is 1.5 m high. I need to extend the cable approx 4 mtres inside the cupboard and negotiate the 2 interior corners and a water pipe using 'trunking'. Can I route it how I like so long as its in horizontal or vertical runs? 4. The heater will be 2kW, what fuse sizes should be used in both FCU?
My questions:
