- Joined
- 26 Jul 2018
- Messages
- 171
- Reaction score
- 6
- Country
Hi there,
I am looking to install some CCTV to my new house.
Having installed some cameras inside at work, I am familiure with how to set them up, I would be using POE ones so just one ethernet wire required.
I was thinking about installing the camera in either of the red dots (these are high enough you would still need a ladder to get to the camera) on the below picture, running the external grade ethernet cable behind the guttering, secured with cable ties, then drilling a small hole into the soffit marked in blue and up into the loft space. I can get to this corner of the loft being slim, so I should be fine in pulling the wire through and then sealing the hole with sealant.
Does this sound like the best way to do this? I would rather not drill through a brand new soffit, but it seem the easiest and most neat way of concealing the wire behind the guttering.
