Hi - I have a ceiling light with just one twin and earth cable connected to it - there is no ceiling rose or junction box nearby. I assume this cable is the neutral and switch return wires and that the red wire is the switch return. I wish to install 6 downlighters and intend to loop this cable in and out of connectors, with flex off to each downlighter. Does it actually matter if in fact the black wire is the switch return but I wire it to the neutral in the connectors?? I will appreciate any advice.
PS Strangely the cable above heads off from the ceiling light in the opposite direction from the switch which controls the light. It's difficult to follow its route but I assume it ends up at the switch.
