Installing RSJ - Padstone Question
22 Nov 2006
Berkshire
Hi all, installing an RSJ this weekend, have had the SE to to all calculations. I have a question relating to a padstone. The wall i am removing is single course between dining room and lounge supporting joists. The SE has said 9" pier on each side. He has suggested a 9" x 4" x 6" padsdtone. They all seem to be 215x215x102mm, 440x140x215mm,440x140x102mm. Is there one the exact size I need or do I have to cut a larger one down? or am I better using a lintel and cutting this down?
When I come to pack between the RSJ and padstone is slate ok to use or is there a better packing material?
As long as the slate can cope with the same bearing stress as the padstone was designed for.
IMO, its not good practice to pack the beam up, but rather put the padstone in at the correct height.
100mm wide padstones are available. Don't try and cut a thicker one down - use a lintel or in most cases, solid blue bricks in 3:1 will do in a domestic job
as woodster says, once you have the beam located then screw a pair of acros under each end and lay the padstones on a bed of mortar.
you can force mortar under the padstone so that it is pressed snug against the beam.
take the props out after the weekend.
