Hello All
Been a lurker for a little while but now that I actually have a issue thought i should sign up and post a question!
The story..
I am doing extensive work to my living room. This includes adding a new ring circuit to the living room, as there has always only ever been one plug socket for the room!
I had a electrician in, explained how exactly he would be doing the job and gave me a quote. Unfourtunatly he never got back to me, despite a couple of phone calls.
I've helped wire plugs in the past etc so its not like im completly new to all this so thought i would have a go myself.
Following what he told me he was going to do, i have cut out all the holes in the wall for the sockets and even wires a few of them up.
However, i have now been told that I am not supposed to (or can not?) have the wires running behind the skirting (I chased out the wall). Is this really the case? I have concrete floor.
Secondly, the wires need to get across from one wall to the next - i was told by the electrician that he would chisel up the concrete so the wires can lay under the ground (and cover over) . Again, is this ok?
Lastly (i think!) is there a minimum height the plugs should be? I checked around and personally felt the height i went for was okay - they were inline with the other socket (and dead socket) in the room, if not a bit higher. I believe i went about 11 inches above the floor (top edge).
Here are some photos..
I will obviously get a proper electrician in to check it and hook it upto the consumer unit.
Until i find out if what i am doing is okay, im going to give it a rest.
Thanks for any suggestions.
The story..
