Hi
I am considering to install solid oak flooring myself. Floor will be layed with 12mm plywood sheeting first. I will be using a porta nailer to attach wood to ply.
Can anyone advise if it is reasonably easy to do or if I should get a
professional in?
Do you normally surface nail the first 2 row prior to the porta nailer?
Is it reasonably easy to get a good fit for the tongue and groove?
I have laid laminate floating floors several times with good results.
Thanks.
professional in?
Thanks.
