Is there a set procedure to installing some stairs? We are having a joiner put some stairs together for us.
They are spacesaver stairs much like the one below (banister is on the other side)
At present I only have a small loft hatch so i need to cut out 800mm width (to match the stairs) and length of about 2000mm (apparently - is that recommended?)
I have a joist every 400mm so I will need to remove one of the joists so the stairs can fit in nicely.
What is the safest way to do this? and how will I attach the stairs as the joists run from the front of the house to the back which is the same direction as the stairs will be going.
Hope that is clearish
a
a
