    Dismiss Notice
Installing stairs - plasterboard before or after?
Discussion in 'Building' started by Cabbyfan, 13 Jul 2018.
  1. Cabbyfan
    Cabbyfan
    27 Oct 2013
    218
    Thanks Received:
    10
    Country:
    Hi.
    I have built a new stairwell which is block on one side on the first riser and timber stud on the remaining two sides if you imagine you have 2 left turns to go through 180 degrees.
    Looking for advice as to should I plasterboard all the stairwell stud before or after I fit the stairs? Personally I think after but wanted to check. ..
  2. Ian H
    Ian H
    14 Sep 2010
    7,026
    Thanks Received:
    852
    Rochdale
    Country:
    I did mine after but it does take a bit of thickness out of the side bit (string/stringer?)
  3. Sponsored Links
  4. cjard
    cjard
    6 Sep 2008
    2,335
    Thanks Received:
    251
    Country:
    Did mine after. Had to get the multitool out and hack a few bits of plasterboard out where the wall was bent otherwise the gap down most of the stringer would have been horrendous
    Also, by the time I fitted stairs I'd forgotten where the studs were for fixing the stringers to
    Would still do it that way again though
  5. Cabbyfan
    Cabbyfan
    27 Oct 2013
    218
    Thanks Received:
    10
    Country:
    Thanks guys always good to get a second opinion
  6. Sponsored Links
  7. Anstiss Ltd
    Anstiss Ltd
    29 May 2018
    68
    Thanks Received:
    7
    Country:
    I have done this before
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
