Installing window gap
30 Aug 2022
I'm installing a UPVC window but there are gaps up to 30mm since my block work wasn't even.
Code:
    10mm
 __________
| 25mm     | 25mm (30mm from outside just on this side)
|__________|
     0mm
Is expanding foam suitable otherwise I was thinking of cutting a wedge of treated timber?
I have some left over upvc soffit materials I can use hide / waterproof the exposed foam/wood edge. On top of this will be more metal roofing sheet I'm using as cladding.
I forgot to add. Do I need to use any damp proof membrane / course material if I'm installing it into a single skin block wall?
