Insufficient power to heat room with UFH
Your measuring the primary circuit, and need to measure the actual loops, which will be loads less than 60c.
Remove the carpet and lay tiles and you will see a big improvement.
5 degree diff on the loops is fine.It may be series pattern, double meander you can go higher. Loop flow temp of 45 maximum.
