- Joined
- 25 Nov 2013
- Messages
- 42
- Reaction score
- 0
- Country
Hi Folks,
I have a small ex-council house and I have been up into the Attic and Extension and what I have noticed the following Insulation:
Attic
Yellow Wool Between Joists folded ontop of itself - ~70mm
Pink Wool Ontop of Yellow between joists - ~50mm
Totals: ~190m But its thicker and thiner in some areas.
Extension
Pink Wool between joists - ~80mm
Do you think I would benefit by topping up the attic and extension to 270 - 300mm?
Right now my house is generally chilly and it does feel like I am loosing heat all the time so I am wondering if adding the extra insulation would make that much a difference in keeping heat in?
Secondly
I have looked around to see if I have any forms of Cavity wall insulation however when I look at both these extensions I cannot see any additional beading or yellow wool despite the fact that when doing a test drill I did find 'Some' Yellow wool in the walls.
If you look in the picture you will see where the Wires enter the house from the extension I would have assumed the yellow wool would have been visible?
Lastly
Would adding some insulation to the roof of the kitchen be a big job?
There is literally about 5 foot clearance so I could not climb up in however there is air bricks I think I could top it up but I am worried about having to first run vertical wood strips etc?
Or can I just set the additional insulation on top?
Any advice would be great
Attic 1: View media item 88461Attic 2: View media item 88462Attic 3: View media item 88463Kitchen Pipes: View media item 88464Kitchen Roof: View media item 88465
Attic
Extension
Secondly
Lastly
