- Joined
- 23 Jun 2018
- Messages
- 74
- Reaction score
- 0
- Country
An extension with a flat roof has been built and BC wants insulated plasterboard installed on top of a vcl for the ceiling.
The plasterer suggested rather than using insulated plasterboard 35mm ( https://www.british-gypsum.com/prod...oc-thermaline-plus-35mm#technical-description ) to use a separate 25mm insulation PIR with a separate 9.5mm plasterboard. He said there is less waste as the insulation boards don’t need to be cut to meet the joists, but only the plasterboard.
I think there are some advantages as the PIR has foil on both sides and would act as another vcl and perhaps it would be easier to install. Are there any drawbacks with this solution ?
