I have a double brick wall without a cavity that I need to insulate.
To achieve the required U value I'm going to be fitting 50mm Celotex directly to the wall and then fitting 25 x 50 battens 600mm apart screwed through to the wall. The joints will be taped and the edges sealed with mastic to provide a vapor barrier. According to Celotex's information this will give me a U value of 0.35W/m2K.
My question is should I use tanalised timber or kiln dried? I currently have tanalised but it has been delivered wet and I don't think I can use it.
Help please as this is now holding up my build.
