Insulating Shed - To Air Gap or not
8 Sep 2020
Hi all,
Just in the process of constructing a new pre-fabbed shed. Planning to store some tools and a few other bits in there so want to make sure it's insulated.
At the moment the shed has 40mm studs. I've picked up some Thermal foil insulation (acts as a vapor barrier), and was also planning to get some celotex too.
I'm reading conflicting info though on the best way to go about actually insulating it. Do I need to leave an air gap or not? My main worry is condensation building up in the gap and not escaping.
If I do leave an air gap (say 20mm) what's the best way to layer materials? Should it be:
Foil attached to cladding - air gap - celotex - MDF/OSB
OR
Cladding - air gap - Celotex - Foil - MDF/OSB
OR should I just get 40mm celotex, leave no air gap and pack the gap with foil, then celotex then board?
Or should I not have the vapor barrier at all? Definitely do not want to trap any moisture inside the shed or create damp/mouldy conditions.
Any help greatly appreciated!
cladding - celotex - foil taped joints- osb
Are you planning to heat the shed? If not, there isn't much point in insulating it.
