Hi all
I’m wondering if someone can help/advice me please.
I have a 1920s house with suspended timber flooring. A lot of work needed to be done but with the cold starting to set in I’m looking to sort one of the rooms downstairs temporarily for my elderly mum due to go through treatment shortly…she is really feeling the cold and only to get worse with her treatment.
I have old rubber underlay with cheap carpet from previous owner on top. The rubber has disintegrated and the room is very cold, so looking to replace the underlay (I have some 11mm cloud 9 left over) and relay the carpet on top. The question is, can I or is it worth adding a foil type underlay under the cloud9 to provide additional insulation properties? Plan was to empty the room, foam around the perimeter between skirting and floorboards to stop cold, foil back the entire floor, then lay the grippers and underlay before putting the carpet back.
Is it worth adding a foil product underneath or would it be a waste of time?
Many thanks in advance for any advice or suggestions…it is much appreciated.
