- Joined
- 24 Oct 2016
- Messages
- 5
- Reaction score
- 0
- Country
Hi All,
i am just looking for some guidance on insulation of the rafters in my loft. I have done some reading around and people recommend insulation boards as they are thinner for a high level of insulation.
The only downside I have noticed with our rafters is whoever built them way-back-when (house was initially built in the early 1900's) managed to build wonky rafters. My dad (DIY 'expert' in his own mind) thinks i should shove 25mm mineral wool down the rafters and board over it; rafters are only 3 inches deep and I believe doing the 25mm would leave the 50mm air gap that is recommended for condensation purposes.
Lastly, I did think about getting thermal-backed plasterboard, give up the two inches of space, and leave the 3 inches as the air buffer. It does also seem that you can only get the thermal-backed stuff in a tapered edge which I hear isn't too good if you have to cut it into funny shapes to fit the wonky spaces.
Any thoughts on the above would be much appreciated. If you need any more details, just ask and ill try and get details.
