Hi All
I am looking for a bit of advice. I currently live in a 1970's built 2 floor semi, with flat roofs above the upstairs bedrooms (front and back) and I have eaves above the ground floor (see picture).
The house itself is very cold. As you can see there has been a bay window extension at some point in the last 10 years, but unfortunatley the bay window hasnt been fit correctly, the ceiling of the bay is straight on to the bottom of the eave, and the radiator for the room is underneath the window. All the heat generated from the radiator goes straight up and dissappears it takes an age for the room to get to any sort of temperature, and i still usually have a hoody on for warmth. The ground floor itself is also open plan with doesnt help (living room into dining room with large doors on to the back garden). The bay window is also poorly fitted, i can get my small finger into a gap and into the eave so it is very draughty, i could probably push the window out if i gave it a good push.
Firstly I am going to try and fix the bay window in a more sturdy manner, and seal where relevant, and then insulate the eaves. To insulate the eaves am I ok to use standard loft insulation, or would something like Kingspan be more suitable?
I was also thinking of bringing the ceiling down on the ground floor and insulating between floors with 100mm Kingspan, would this be a good idea or with it stop the natural warmth rising through the house to the 2nd floor?
Along with this I am hoping that resiting the radiator (a new double finned one) to a different location within the living room, and the addition of some french doors between the living room and dining room with hopefully give me some more warmth.
By the things that I have found around the house, it has been a bit of a DIY'ers paradise, unfortunatley the DIY has been to a poor standard.
I should also mention that I have had cavity wall insulation installed, and there is some insulation in the loft, however due to the flat roofs above the bedrooms I am unsure if there is any insulation above the bedrooms, I will rectify as and when i decorate the rooms by bringing the ceilings down and insulating with kingspan (if recommended)?
(open plan living room to dining area - sorry about poor picture)
Alex[/img]
Alex[/img]
