Insulation questions
4 Aug 2013
London
I am just doing a large refit of our new house and I have a few insulation questions.
The house is solid walled and needs some insulating which I will be doing inside. My main worry is creating condensation where it shouldn't be by not doing it properly.
I am currently on the bathroom/kitchen and i have a few plans.
The bathroom is the room I am working on but the kitchen will also need doing when we refit it so I want to make sure I don't have to redo anything when I get to it.
My current plan is to add insulated plasterboard to the somewhat uneven external brick walls (no render on them anymore) most of which I am ok with but there are 2 options available.
1. Just insulate the bathroom after the floor has been finally fitted.
2. insulate the bathroom and then continue the plasterboard through the floor void into the kitchen, (i.e do the whole external wall) then fit the floor and kitchen ceiling up to the plasterboard wall lining this also insulating the floor void.
my main thoughts are about fire regs doing this and also what do I do about the floor joists where the rest in the external wall, I am aware that these will become the coldest spot, can I just fill with foam to seal, will this stop condensation?
I obviously want to insulate as much as possible while I have no floor ceiling what are the best options?
cheers
There's not much point in insulating the wall between the floor joists - it won't cause any condensation issues
I have taken down all of my downstairs ceilings and insulated then doubled boarded the ceilings, the difference in heat is unbelievable.
I also have 400mm loft insulation in the loft.
Andy
Thanks thats good to know, out of interest what insulation did you use? what did you do about the bit where the joists meet the wall?
Cheers
Loft insulation was from wickes, I cut the rolls 20mm thicker to fit snugly between the joists, I ran from wall to wall. I cut the insulation while it was still wrapped up. Then once pushed into the joists I covered the joists with a polythene sheet that I stapled to the joists to make sure the insulation didn't fall out/down.
Then doubled boarded with 12mm plastered board and plastered.
Andy
It is much quieter now, I can't hear the kids fighting upstairs now!
Also I can watch tv without it waking them up in the evening.
Andy
