I am just doing a large refit of our new house and I have a few insulation questions.
The house is solid walled and needs some insulating which I will be doing inside. My main worry is creating condensation where it shouldn't be by not doing it properly.
I am currently on the bathroom/kitchen and i have a few plans.
The bathroom is the room I am working on but the kitchen will also need doing when we refit it so I want to make sure I don't have to redo anything when I get to it.
My current plan is to add insulated plasterboard to the somewhat uneven external brick walls (no render on them anymore) most of which I am ok with but there are 2 options available.
1. Just insulate the bathroom after the floor has been finally fitted.
2. insulate the bathroom and then continue the plasterboard through the floor void into the kitchen, (i.e do the whole external wall) then fit the floor and kitchen ceiling up to the plasterboard wall lining this also insulating the floor void.
my main thoughts are about fire regs doing this and also what do I do about the floor joists where the rest in the external wall, I am aware that these will become the coldest spot, can I just fill with foam to seal, will this stop condensation?
I obviously want to insulate as much as possible while I have no floor ceiling what are the best options?
cheers
cheers
