I have neon indicators in four circuits, 13A FCU, 3A FCU, Cooker, Shower circuits.
1. Should the tests be done with these switches closed, or is there a chance of damaging the neon lights?
2. If they should be excluded because they are "sensitive" equipment, are the tests done ...
2a ... with the switches open (which means you are excluding part of the circuit?
2b ... with the DP switches taken out so you can test from the CU to that switch and then test at the switch for the remainder of the circuit?
2c ... with a connector block to connect the ongoing leg so a full test can be done from the CU?
