Integral garage - plasterboard ceiling access hatch
30 Sep 2008
Aberdeenshire
My bathroom is directly above an integral garage. I recently completely refitted the bathroom and removed the plasterboard ceiling in the garage to complete all of the plumbing and drainage from below (which I had to do to gain access to the drains etc). I now intend to refit the garage ceiling using double thickness plasterboard for fire regs etc. However, I need to fit a small access hatch for the shower trap (as I fitted a low profile tray directly onto the floor) and was wondering how best to do this to comply with the relevant regs? Do I need to buy a fire rated panel (which are pretty expensive), or can I just make a double thickness plasterboard panel fixed on with plasterboard screws?
Thanks,
Graham
3 Sep 2006
West Mids
Yes, but you need to sort out how to seal or cover the joint around the hatch/cover
27 Aug 2003
London
Would an intumescent strip like you sometimes see set into the edge of fire doors do the trick?
22 Feb 2008
Norfolk
If the hatch and strip were set in a subframe like a normal door arrangement, can't see why that wouldn't work.
3 Sep 2006
West Mids
Yes door int.strip swill do, but its the installation as a whole which matters, so it's the actual hatch, the frame and the seal. And the hatch must be suitably fixed, not just plonked into the frame.
16 Nov 2013
Buckinghamshire
I've just fitted the same type of shower base, it does look so much better than a raised one doesn't it !
I bought a top access waste to save the hassle of having to fit an access door. It was only a couple of £ more than a standard type. Compared to the cost of buying or making a fire retardant hatch it is well worth it I think. :D
27 Aug 2003
London
16 Nov 2013
Buckinghamshire
No worries, I wasn't offended just going along with it with my response. Thought his quick reply of such an elaborate post very funny actually
I did fell a bit daft responding to such an old thread anyway ! :LOL:
27 Apr 2008
I think that was excellent BAS - I have saved that image for later use myself. :LOL:
