- Joined
- 15 Jul 2015
- Messages
- 7
- Reaction score
- 0
- Country
We have an integrated CDA Fridge Freezer which is over 10 years old and the freezer seems to have given up the ghost. Instead of getting it repaired we've decided to replace it. However I am not sure which measurements I should be using to identify the correct ratio of integrated fridge/freezer to buy. These are the measurements I have
Fridge freezer door length dimensions
Fridge 100 cm
Freezer 63 cm
Closest ration 60:40
Outer cabinet door length dimensions
Cabinet door over fridge 124 cm
Cabinet door over freezer 74 cm
Volume of fridge and freezer
Fridge 200 litres
Freezer 60 litres
Closest ratio 80:20
As you can see the ratio based on the volume of the compartments is significantly different to the ratios arrived at using lengths.
Which ratio should be used? Many thanks.
Fridge 100 cm
Freezer 63 cm
Fridge 200 litres
Freezer 60 litres
Closest ratio 80:20
