I have a power shower which was professionally installed about 18 months ago and has been brilliant. It is the type where the pump is actually inside the shower unit on the wall.
It now will randomly stop pumping water although the pump itself is still running normally. If I then leave it for about an hour it then works
normally again.
Could this be being caused by an airlock?
The hot feed comes off a Surrey Flange on the tank and the cold feed comes off its own pipe from the cold tank in the loft. Opposite end of tank to the cold feed to other taps.
Any help as to how to solve appreciated.
normally again.
