i usually use brown for live, black for neutral (you should tape this blue so you can see its neutral) and grey for ICa1topdog said:When connecting the above I need to use 3 core and earth 1mm cable.
I have bought the new colour cable (Black/Brown/Grey) - the question is
what colour should I use for:
1) Live
2) Neutral
Thanks.
a1topdog said:Assuming I use the black as the neutral , when I run the feed from the CU would it be frowned upon if I used the same 3 core (I've a big roll of it!!!) and snipped the grey at the CU and first alarm?
Lectrician said:Never earthed any of mine down! Snags and solutions - huh!
