A couple of questions for you guys who know/have fitted these boilers (combi)
1. is it possible to position the flue adapter which fits on the boiler flue outlet at 45degs? Manual only shows straight towards back of boiler or at 90 degs. to the side
2. if not, with the normal 90 deg. adapter facing back is there room for a 90 deg bend to turn it to the side? i.e If I used this set up would the flue end up inside the wall the boiler is mounted on?
3. (sorry) My understanding of the regs, and I will ask my engineer when I find one, is that the flue must be at least 200mm from eaves. does this mean the outlet, or does it mean the total circumference of the flue. In other words if I keep the flue sticking out past the eaves by 200mm does this comply, although the flue tube, if I can call it that, may be closer than 200mm to the eaves.
being a bit of a pain on this but trying to do as much research on this as I can. The joys of living in the boonies. Thanks.
