Boiler installed less than a year ago and been working absolutely fine. Last night we've no heating and notice the boiler is locked and fault code 5 is displayed.
Pressing reset button and it goes through firing sequence 3 (vent), 4 (ignition), 5 (CH). Once at 5 you can hear the fan speed drop and eventually it goes back to step 3 and starts over. It does this about three times before locking out and throwing fault code 5 in display. We've had heating for about one hour this morning without changing anything, but now back to fault.
Manual says:
Why would the gas valve need adjusting? Does anyone work with these Intergas boilers and can make some suggestions please? I've contacted the installer and awaiting response, so posting here in the mean time
Manual says:
- Condensate drain blocked
- Check adjustment of gas valve
