Update....
Official Intergas service engineer came over this morning.
After a lot of head scratching, 3 cups of tea, about 6 calls to the Intergas technical department, changing sensors S1, S2 and the PCB....
.....Still NOTHING!, the boiler sat on operating mode 1 after its initial run of around 5 minutes.
He ran it in test mode, and some other testing type modes which worked fine, tested everything he could like the flue readings, gas valve pressure, etc..
He claimed he had never come across anything like it, but everything indicated that the boiler is not at fault and it has to be the programmer, stats or wiring. He said there would be no charge and all new parts are fine to keep in - Can't fault that kind of excellent, no nonsense customer service!
He spoke to my installer over phone and explained. Installer came over right away, as Intergas guy was leaving, they met. Intergas guy decided to stick around as he was curious and intrigued.
Installer ran a brand new cable with wall plug and powered up boiler to bypass all wiring, switched on.... still nothing.... Intergas guy looked puzzled. Installer then ran direct new cable from pump too to be sure, still nothing.
Intergas guy gets back in touch with tech dept, explains problem points back to boiler. Tech dept once again: check flow, flow return, pump, same things installer has been told over the past week... Still nothing.
Intergas guy then changes "wire straps"- wiring looms that go between sensors and board and you guessed it, still nothing. Phones tech again, requests authorisation to try new fan... still nothing.
Finally, he requests tech dept gets in touch with the tech Guru in the Netherlands.... Tech guru says connect terminals 4 and 5 on the low voltage side. He connects 4 and 5, and VOILA!!!! everything comes to life... we all look at each other in shock/relief/ excitement?
Checked everything, and seems fine, all demands from programmer result in boiler starting up right, heaters coming on etc.. all done finally!
Intergas guy had no idea about and would never have tried connecting 4 and 5 and doesn't know what it did and how and why.
The only thing we could conclude was, as this boiler has a manufacturing date of march 2014, and is so new, the pcb has some sort of update ( he claims theyr'e always improving and updating components) that hasn't been explained to the UK tech dept yet? - He will be bringing it up with Intergas in the Netherlands on his next regular trip there.
They both left and I was relieved and very happy obviously. I left the heating on, but about an hour later, just as I was about to pop the Champagne, I noticed the boiler had been running pretty hard, and hadn't really slowed down at all or stopped, the heaters were REALLY hot and uncomfortable to touch.
I don't know what to really expect from condensing boilers, but expected it to reach its flow temp then slow down or shut down, I felt a little gutted as it just didn't feel like it was running as it should.
I lowered the CH temp from 80 to 70, as I did this and saved the setting, there was an instant lowering in speed and going even lower, a shutdown to code 1. - Promising!
After around 5 minutes, it would start up again, which seemed normal and what it should do, but I found it would not slow down or shut down once running again from that point or restarting , which can't be right. - Gutted again!
I decided to take the front cover off, and found that a small black of wire had been left off. Looking at the manual, I found that connectors 9 and 10 on the low voltage side say "boiler thermostat" or something like that. I decided to try connecting this there.
Although I haven't had a chance to test it for a long period and vigorously yet, it seems to have done the trick and the boiler ticks over quietly after its initial higher fan speed, while holding a lower temperature of 62 degrees which I found more suitable , heaters are much more comfortable and don't feel like they're going to burn your skin off... I just get the feeling it is running right now.... I hope! Fingers crossed!
