- Joined
- 12 Aug 2009
- Messages
- 8
- Reaction score
- 0
- Country
Hi all!
I'm about to lay laminate flooring in our hallway and I have a question re the door frames. In the other rooms we cut the laminate around the door frame, this cutting was mostly covered by the trim over the join between the flooring but is less than perfect I would say.
This was ok because those rooms only had 1 doorway, my hallway has 3. I have also since read that you are "supposed" to cut the bottom of the frame and slot the laminate underneath. This makes sense if you are laying solid wood floors but the laminate stuff has to be clipped together in a whole row and then that row clipped to the previous and lowered to the floor - how can that operation be achieved while slotting it underneath the doorframe?!
Also a more simple question - is there a standard as to which way the floor boards should be layed with regards to a front door? i.e. lengthways or perpendicular to it? I know normally the board is run along the longest lenght of the room but the hall is quite small and almost square (maybe 2m x 2m).
If I chose to run the floor through into the downstairs loo (which at some point does need a floor!) how would I go around/under the frame and should the boards be going across the doorway or is the other way acceptable? Is it even possible to continue the flooring seamlessly through a doorway I guess you have to stop and have a join so there is an expansion gap?
Finally, if I put the floor down then use the skirting to cover the expansion gap (there is currently no skirting in the room it's just been plastered). Then does this mean if we ever need to change the floor we'd have to rip the skirting off? Any tricks I could do to plan ahead for this?
Dave
Dave
