Intermittent outside light
17 Nov 2005
Manchester
Hello,
We had an outside light fitted some years ago, the light we chose was a PIR however it never worked right and I swapped it for a simple on off switch (light fitting replacement only) the old PIR light still operated through a switch that hasn't changed. Now, the light only works intermittently, there isn't a pattern like having to have another light on etc, it is in a switch with one other 2 way light. Any ideas please guys.
No flickering etc, just works or doesn't, no pattern.
I agree with eric but check the terminals in the lampholder for corrosion at the same time
I will have a look at the bulb and the fittings, the lamp is quite new (last summer), thanks guys
