I recently bought a house that has an old ( only one button that pops out when the circuit is tripped, no test button) gfci outdoor recpectacle installed. From that receptacle are light switches for a swimming pool, a gazebo and garden flood lighting. The configuration on the flood lights is Receptacle ----Fixture ------ Fixture. On the other side from the receptacle are the 3 switches. The pool light has 1/2 of the box and is installed vertically. The floodlights and gazebo share the other 1/2 of the box and are mounted horizontally with the flood light switch above the gazebo light switch.
At times all 3 lights work, but at other times the receptacle GFCI switch pops disabling the pool and floodlights. The gazebo light always works. They will all work one night and then not the next. Or the pool and floodlights will be working and then trip, they are always on or off together. It is often days or weeks later until it works again. I have not be able to discern a pattern.
Does anybody know what may be causing this? And can you point me to where to look to repair the fault.
Thanks,
Sam
Thanks,
Sam
