Internal doors irregular size
7 Aug 2009
Staffordshire
Hi can anyone tell me where I can get some internal doors, I'm completely useless with a saw so any alterations are out there question. My door frames are 810mm X 1975mm
1981mmx 838mm is a standard size door, any door you buy will need trimming, you also need more than a saw to fit them, and if useless with that how are you with all the other tools needed? if you are not able to DIY then just get a joiner to do the work.
just be careful some lipped doors have a maximum perhaps 6-10mm you can remove from each edge which can effect there suitability as a 2-2,5 gap top and edges will just about work [pushing to 12mm trim]with an 838 door if fully parallel but iff slightly diamond [not fully parallel]by say even 5mm you may come unstuck
