just looking for some advice,
I’m renovating the house, it’s a 70s house.
Currently installing underfloor heating in the upstairs bedroom, have removed the entire floor, battened out the joists and installed 50mm solid foam insulation with under floor heating pipes on top.
have foam sealed around the joists where they are set into the wall, and added more 50mm insulation vertically between them.
So the under floor itself has been relatively well insulated, on top I’m installing 22mm chip board flooring which will be glued between the joints and foam sealed around the edges.
so now I’m focusing on the walls.
House has a 50mm cavity filled with the fluffy mineral wool insulation on 1 exterior wall.
so what I wanted to do was build an internal stud wall, install 50mm rock wool between the studs, then vapour barrier over the top and plasterboard.
on the adjoining other exterior wall, there is no cavity... on the exterior there is a felt membrane and tiles as cladding, then there are basically just hollow concrete blocks and plastered on the inside.
on the inside, want to build a stud wall with 100mm rock wool insulation and again vapour barrier and plasterboard.
so 100mm insulation total on the external walls with vapour barrier and plasterboard...then continue this vapour barrier across the ceiling before over boarding with a 2nd layer of plasterboard. All to try and increase the air tightness a bit and insulate the room better even if it reduces the size slightly to try and maximise the benefit of underfloor heating and keep the heating source temperature as low as possible.
once I’ve done this room I will continue the same theme throughout the other upstairs bedrooms and exterior walls downstairs as well.
but I just wanted to know if there was any special considerations I needed to take into consideration?
thanks
thanks
