- Joined
- 15 Jan 2025
- Messages
- 2
- Reaction score
- 0
- Country
I am rebuilding our ensuite following a leaky shower issue a while back. We decided to rip everything out and start from scratch.
The house was built around 2005. It’s standard construction with brick and cavity wall, which as far as I can tell is filled with yellow wool insulation.
I plan on battening the external wall to make it easier to fit tile backer boards. I feel I will personally achieve a better result than using the dot and dab method. My question is whether we need to insulate between the tile backer boards and the wall?
Before it was just dot and dab plasterboard with no insulation.
Two of the walls are back to the grey brick but its only one that is external. The other is a party wall.
Thanks for your help.
