Hi there.
I have for the last few months been having problems connecting to the internet from time to time.
I use Virgin Media via cable.
Sometimes when I try to connect, I get the usual dns error page as if I am not plugged in or the modem is switched off etc.
I have contacted Virgin 4 times now with the following answers...
1st time: Various checks, went away, called me back after half hour & said "you wouldn't believe it but someone else has the same MAC address as you & is connected. Whoever connects first wins! He renewed my IP address anyway & it worked ok for a day or 2.
2nd time: Same checks, including renew IP address, didn't work. He called me back, said it was a "problem at our (Virgins) end" & they had sorted it. Problem solved for a few more days.
3rd time: Same checks, same result, same answer. Same fault back again.
4th time (tonight): "I guarantee to fix this repeating problem sir, don't worry, you will not have to call us again to solve this...etc etc etc". This guy got me to check my IP address (after restarting computer & modem) - found to start 169.***.etc. Renewed IP, now working. He tells me it is a problem with my computer that is causing the fault, told me to follow the same procedure & it would work if it (when it?) happens again.
I reckon it is the same issue time & again. 3 different answers from Virgin, the last one implying it is a problem with my hardware.
Does anyone have a clue what I should do to sort this if it happens again, other than just renew IP?
I am running Windows XP, with Norton Internet Security & Norton Personal Firewall active.
Any help or suggestions would be helpful...Thanks.
