- Joined
- 5 Jan 2020
- Messages
- 15
- Reaction score
- 0
- Country
Hi
Due to corrosion on the bezels I need to replace the downlighs in the bathroom.
they’re on a dimmer, I’m not sure if it’s just the lamp that needs to be dimmable or if the fitting needs to be capable too?
Looking at replacing this:
With something like this:
www.toolstation.com
Using the same gu10 lamps in the current fitting.
That is unless anyone can point me in the direction of brushed chrome bezels that will fit the current ones or a better alternative unit?
Enlite IP65 Fire Rated GU10 Downlight EN-FD103SN Satin Nickel | Toolstation
• 30, 60, 90 minute fire rated • Complies to Building Regs parts B & E • Lamp not included • Order for Enlite LED 5W 500lm warm white lamp • Diameter 86mm. Depth 130mm. Cut out 75mm IP65 with loop-in/loop-out terminal block. • Order for Enlite LED 5W 520lm cool white lamp •...
www.toolstation.com
