    Dismiss Notice
is 10mm the same as 3/8 ? help needed
Discussion in 'Tools and Materials' started by moghm, 12 Apr 2009.
  1. moghm
    moghm
    19 Jun 2006
    15
    Thanks Received:
    Manchester
    Country:
    Hi Guys,
    Help appreciated. Needed a 10mm masonary drill bit for a diy job, and then realised that shops are closed for easter sunday. I have found a brand new drill bit tha says 10 and the 3/8 undreneath it. Does this mean that the drill bit is 10mm and that I can use it ?
    many thanks
  2. Sponsored Links
  3. noseall
    noseall
    2 Feb 2006
    42,590
    Thanks Received:
    2,638
    Staffordshire
    Country:
    3/8" translates to 9.525mm.
    So, go ahead and use the drill bit. As it is masonry it won't make a jot of difference.
  4. moghm
    moghm
    19 Jun 2006
    15
    Thanks Received:
    Manchester
    Country:
    many thanks
  5. breezer
    breezer
    3 Jan 2003
    23,324
    Thanks Received:
    30
    Sussex
    Country:
    Tip for the future: You could have drilled a test hole else where to find out.
  6. ^woody^
    ^woody^
    3 Sep 2006
    33,361
    Thanks Received:
    4,523
    West Mids
    Country:
    Another tip - jig a 3/8 drill around a little to make a 10mm hole
  7. neds
    neds
    18 Nov 2007
    929
    Thanks Received:
    28
    Country:
    I've got a nice selection of bent bits that I've leant to people because they couldn't be bothered to use the right size drill bit, think they were trying to drill a 8mm hole with a 5mm bit! :rolleyes:
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
