Is it a faulty TRV?
6 Dec 2007
Dundee
I very rarely have the radiator in my bedroom turned up very high. It's normally on about 2 or 3, but the other night, it was really cold, so I turned it up full. Now the bloomin thing won't turn down. It will turn off, but it seems to just be either full heat or no heat.
Is it a faulty TRV?
The same thing happened last winter as well. Turned it up full once and then couldn't get it to turn off at all. The TRV was replaced at that time.
I'm either dying of heat exhaustion or freezing!
Erm, must confess, I haven't checked. I'm always frightened I undo the wrong thing and flood the place.
I will have a look and report back.
full or nothing is correct operation
it turns the radiator off when up to temperature and on when it drops below
unless your saying it only operates at the extremes eg fuly on and fully off
But it's going to full boiling hot heat when it's only on 2 or 3 and isn't going off to cool down - it's just staying really hot all the time (or am I being dense and missing the point here?)
My other rads will cool down when they reach the relevent temperature, then heat up again when the room gets cool - this one just isn't doing that.
they are desighned to give ful heat the only time they give less than full heat is whilst the water cooles down in the radiator
turning it down to half [3] dosnt give you half heat
so your idea is spot on may just be a bit sticky
remove the top and press the the valve "button"several times and hopfully will clear its self
