I have a Vaillant ECO max 800 (approx. 17 years old) running 8 rads in a medium sized semi. Recently the last two rads on the circuit haven't been heating up fully. They don't need bleeding and I don't think the system can be furred up, because one of the rads is only a year old and there was no evidence of sludge when it was changed.
I turned the Hall thermostat up to full ( about 30 degrees) and shut off all the rads except the two culprits and the Hall rad which has no TRV fitted. They did heat up, although the new rad was only warm at the bottom.
I watched the boiler and it was firing for about 30 seconds until the temperature went up to around 90 degrees then going into anti cycling mode for about 4 mins before firing up again when the temperature had dropped to 60 degrees. I had a thermometer next to the Hall Thermostat and it never reached above 20 degrees so in theory it was calling for heat.
My question is. Do you think that this is normal behaviour from the boiler or should it be firing for longer?
