We had central heating installed a long time ago and the main gas feed pipe run the length of our upstairs landing, from the front bedroom across the landing and into the bathroom, shortly after we put laminate flooring into the bedroom and noticed the door was jamming when closing, shaved the bottom as much as I could but still jammed a little, then we put carpet down on landing too.....fast forward 18 months and carpet on landing has a massive ridge were a floorboard is lifting up, were taking carpet up anyway to replace with new so at same time I took up laminate to address the problem...
The floorboard was sitting directly on-top of the main gas feed pipe and had even made an indentation on the underneath as we had been walking on the landing, attempts have been made to chip away the joist so it can be pushed further down away from the floorboard but this sounds well dodgey to me...
Landing now still has a slight arch were the floorboards haven't been put down level, the pipe has not been removed and refitted to a lower position so am not sure if it is still unsafe
Can I please have you opinion
lee
lee
