- Joined
- 28 Dec 2021
- Messages
- 122
- Reaction score
- 6
- Country
for reasons I'd rather not discuss on this forum, we need to make some slight alterations to our plans. long story short, 3.9m single storey rear extension, flat roof with 2 skylights. we want to open up as much of the existing rear, load-bearing wall as possible.
the initial plan involved a boxframe, which could hold the weight of the world.
we want to revert to a simpler plan instead, namely a single steel beam to hold as much of the first floor as possible. width of the house, end to end, is 6.65m, all walls are cavity, 300mm wide, brick in/outside.
structural engineer claims we can only open up 3m as we need at least 1.5m each side due to the existing foundations (strip, ~30cm deep concrete + 6 courses engineering brick) not being strong enough. builder disagrees and says 600mm each side would be more than sufficient.
before I approach another structural engineer, may I just check that it should be possible to open up more than less than half the width of the wall and that this engineer sounds overly cautious?
thanks
thanks
