Is there a good reason why window boards have horns?
11 Dec 2019
Not sure if this is the apprrpriate forum as I expect some pushback. In my defence I love wood as a material and have replaced window boards with oiled hardwood in a previous house.
I'll be replacing all the window boards in the house with new. Every rooms will be replastered and there will be some internal insulation being added as well.
Following an example that I found in the US, I intend to replace all of them with quartz or granite or similar. It is such a practical surface and doesn't suffer any of the maintenance and damage issues that affect traditional window boards. UPVC are very easy to scratch and look cheap, wood is lovely, but needs maintenance and is easily damaged by water and sunlight.
Now to the original question. Is there any reason other than aesthetics why window boards have horns? In my opinion all they do is clutter the window/wall junction. They are more difficult to plaster and decorate and do not appear to serve any useful purpose.
I am open to persuasion
Regards
Tet
You would usually plaster once the window boards are installed (And undercoated), so because you cannot perfectly predict the plaster thickness you need to either allow a horn, or risk the board not quite making it as wide as the finished window reveal.
I always allow horns, only about 25mm, and bullnose them to match the front edge. Thinking of how a reveal would look without them, I think it wouldn't look good, even if it perfectly matched the reveal size.
