Is there an option to improve gasket on bath overflow?
5 Oct 2014
Hertfordshire
Hello,
I'm in the process of installing a new bath and having a little trouble installing the overflow. I'm finding that it is really difficult to get a good seal with the supplied rubber washers due to slope of bath. Everything just keeps moving around and ending up not centered and I don't trust it not to leak. I tried using some silicone but if anything this made the seal worse as everything slid around. Im also starting to scratch the bath surface around the overflow while faffing around trying to get everything centered and tight.
Are there any options to purchase an upgraded gasket/seal so I can get a nice seal on a bath where the overflow end is angled?
Thank you
Fernox LS-X or silicone if you have some already.
I clean plastic with meths prior or alcohol wipe.
Never had an issue tbh. Don't even think about it. As long as the washer at the back outside the bath covers the hole and is compressed, it'll be fine. I always test by filling bath or spraying with shower.
