Is there such a thing as liquid DPM?
15 May 2013
I did a slab around 6years ago with no DPM underneath. I have since built walls and a roof over this slab but have problems with moisture build up mainly due to the metal roof. I wondered if I could run some tanking slurry or liquid DPM (if it exists) over the top of the slab to prevent moisture getting through the slab. Its not a habitable building its just a shed/outbuilding. What are my options here?
Thanks for your help
They certainly exist, but I don't see what a metal roof has to do with rising damp.
Condensation from a metal roof will fall onto the floor
Ground water may come through concrete unless stopped by a barrier
Aquaprufe and Synthaprufe.
It's possible to throw grit on the surface before it sets so that a screed or wearing layer of fine concrete will adhere. Without the weight of a screed or extra layer, water pressure can push it off.
There are some soak-in waterproofing treatments applied to concrete tunnels and the like but I have never seen then used.
The Royal Navy used to swear by a certain liquid DPM for several centuries. I suspect it still exists.
Thanks for the replies guys. I have some left over tanking slurry so shall put that on the floor and then see how it is before adding anything else like Aquaprufe.
If you're going to do the floor to stop moisture coming up, then you'll need to think about a DPM in the walls, and then take the slurry up the walls to join the two.
