Is this just a solid fuel fireplace with a gas burner installed infront ? The semi circle piece above the coals is a metal plate so where do gases go ?
I certainly would not be using this fire as products of combustion are likely to enter room instead of chimney. Good chance it will make you drowsey, even kill.
