- Joined
- 28 Dec 2021
- Messages
- 120
- Reaction score
- 6
- Country
rear extension, I made my own drawings, we're working with building control. I found out there's a public drain in my back garden, foundation will go over it (perpendicular). I am looking to apply for a build over agreement, will this be ok?
basically the invert level is at 0.7m (surveyed), but the foundation will be around 1.0-1.2m deep (based on the builder's experience from local works).
would this work or do I need to make any changes? I left 200mm each side, as opposed to the minimum 150mm required by thames water.
1. should I have more courses of engineering bricks under ground level?
2. should the lintel be right under the first row of engineering bricks and the rest filled with pebbles? isn't that too much pebble?
3. is anything needed UNDER the pipe? do I fill that bit with concrete (up to 200mm under invert level), then fill with pebbles 200mm above, then lintel?
thanks
thanks
