Other saving strategies? Do you not have thermostat set to say 21 degrees so it comes on and off as needed?We were looking at a new boiler and the saving is small if you turn on but it is a saving
3-5% in running cost.
Up to you if you use it.
Add a few other saving strategies and maybe you could save 10% a year.
That's £200.
Bit difficult in our house as it's whacked on high 24/7, even the lemons plants are wilting!
Ha
Can anyone tell me if having weather dependent really is worth turning on
Well i spoke to a worchester bosch after service person and they told me its not worth having on but that was an off the record remark and i just want to see what other experts think?Do you imagine that they would include the feature if it did not work?
I had it on on sunday it was 18 degrees i wanted to get it up to 21 degrees. It modulated at a decent enough heat to 20 degrees then modulated away down and spent over an hour trying to creep up the last degree. I actually think i just switched it offInteresting!
That is how our wireless roomstat/programmer works the boilerRight, the idea is that it modulates to the lowest possible flow temperature that will be sufficient to reach the temperature you want.
So maybe taking an hour to do the last one degree is "working as intended". Or, maybe you need to slightly adjust the parameters. I have no idea about your boiler, but I imagine there will be a setting you can adjust that affects its relationship between the external temperature and the water temperature. Turn this up a bit.
It was actually about a week after i had got it installed. I was walking to pick up my son from school and there was a worchester bosch van sitting in a neighbours drive and he was sitting in it. I asked him could i ask him a quick question he said sure. So i asked how i set up the weather dependent. And he said to be honest i would not put it on its more trouble than its worth. I am sure he would not have told the people at the house he was at the same info tho as they could report back to office if he said it to them.It looks like you understand it....
Curious to know why the "after sales person" thought it is worthless.
I am not convinced weather dependent is right for me. I have it set to have house to temp for 730am. Its coming on at 5am. I think with off it will come on and at at a hotter temp which yes is a bit harder on the gas but i dont know i just feel at a hotter temp for less time still might save money. I am not penny pinching i just want to run it at optimum leave.It looks like you understand it....
That's what the weather dependant setting does, saves having to do it manually.i just want to run it at optimum leave
