isar HE24 no lights on the control panal
18 Mar 2016
Hi hope someone on here can help
I have just purchased and moved into another house and can not get the HE24 boiler working
when I turn on the boiler makes all the right sounds like its working and I can feel a small amount of heat from the base of the boiler, but all the pipes are cold , no hot water or radiators, there are no lights on the front control penal and the code window is not lit
I checked the jumper in the orange pcb but it fell out as I touched it and I'm not sure where it goes, there is only one and it was on the right side if that helps
iv also checked the connecting wire to the pcb and its was clean and tight
any insight will be grate
